Ga door naar hoofdinhoud
Help
MacBook Unibody Model A1278 LVDS Display Cable Replacement
Replace the LVDS display cable in your MacBook Unibody Model A1278.
This guide will show you how to replace the LVDS display cable.
Stap 1 LVDS Display Cable  ¶
Carefully route the LVDS display data cable through the slot located to the left of the antenna assembly. Do not use excessive force as you may damage the LVDS display data cable.
  • Carefully route the LVDS display data cable through the slot located to the left of the antenna assembly.
  • Do not use excessive force as you may damage the LVDS display data cable.
  • Lift and remove the LVDS display data cable from the display assembly.
