Ga door naar hoofdinhoud
Help
Fujifilm FinePix 4700 Zoom Battery Compartment Replacement
Heeft betere plaatjes nodig
Betere foto's zullen deze handleiding verbeteren. Help mee door het nemen, bewerken of uploaden van nieuwe foto's!
This guide will help you install and remove the battery compartment on the camera.
  • Auteur: Lawrence Yang
  • Geschatte tijd: 25 minuten
  • Moeilijkheid: Gemiddeld
In order to access the battery compartment, the back cover of the camera needs to first be removed.
Secties
Stap 1 Battery Compartment  ¶
Locate the wires running from the battery compartment to the main motherboard.
  • Locate the wires running from the battery compartment to the main motherboard.
  • There are two sets of black and red wires.
Stap 2  ¶
Use the tweezers to grab one set of wires near where it connects to the motherboard. Pull the set of wires straight out. Repeat these steps for the other set of wires.
Stap 2  ¶
  • Use the tweezers to grab one set of wires near where it connects to the motherboard.
  • Pull the set of wires straight out.
  • Repeat these steps for the other set of wires.
Stap 3  ¶
Lift and pull outward (at the same time) the two battery clips that are next to the screen. The battery compartment should now be detached from the rest of the motherboard unit. The battery compartment should now be detached from the rest of the motherboard unit.
Stap 3  ¶
  • Lift and pull outward (at the same time) the two battery clips that are next to the screen.
  • The battery compartment should now be detached from the rest of the motherboard unit.
