Help
GoPro HD Hero2 Battery Replacement
GoPro HD Hero2 battery replacement.
Replace your dying GoPro battery with a fresh one. If you're ready to jump off a mountain, your battery should be too!
Secties
Gereedschap
Relevante Onderdelen
Stap 1 Battery  ¶
Slide a plastic opening tool between the battery and the rear case. Gently pry the battery up and out of the rear case.
Stap 1 Battery  ¶
  • Slide a plastic opening tool between the battery and the rear case.
  • Gently pry the battery up and out of the rear case.
Stap 2  ¶
Remove the battery from the case.
Stap 2  ¶
  • Remove the battery from the case.
