Ga door naar hoofdinhoud
Help
LG VX8700 Front Bezel Replacement
The guide outlines the steps necessary to replace the Front Bezel in the LG VX8700. The Front Bezel is the front frame around the LCD screen.
  • Auteur: Stanley Thomas
  • Geschatte tijd: 5 - 10 minuten
  • Moeilijkheid: Gemiddeld
Stap 1 Front Bezel  ¶
Turn your phone around and open the flip phone.
  • Turn your phone around and open the flip phone.
  • Locate the two grey rubber plugs on the LCD portion of the phone. These plugs cover up two screws.
  • Remove the two grey screw-covers at the bottom of the screen
Stap 2  ¶
Remove the screen by using the tab to eject the screen. There is a gap between the case and the screen near the ear piece
Stap 2  ¶
  • Remove the screen by using the tab to eject the screen.
  • There is a gap between the case and the screen near the ear piece
  • Insert the plastic opening tool in the gap and pry the screen up.
  • The plastic screen cover is glued onto the phone, do not be alarmed if it may be difficult to pry it off.
Stap 3  ¶
Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
Stap 3  ¶
  • Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
Stap 4  ¶
Turn your phone around Remove the top cover of the phone by inserting the plastic opening tool into the groove.
Stap 4  ¶
  • Remove the top cover of the phone by inserting the plastic opening tool into the groove.
  • Carefully open the cover.
