Help
SanDisk Sansa C250 Front Case Cover Replacement
Onjuiste gereedschappen
Help om deze handleiding beter te maken door de juiste gereedschappen in plaatjes en/of tekst te gebruiken.
Opsommingstekens!
Opsommingstekens!
Betere coördinatie met markeringen en kleur/type bullet points om deze handleiding nog duidelijker te maken!
Verwarrende Tekst
Verwarrende Tekst
Een deel van de tekst in deze handleiding is verwarrend, dubbelop of naast de kwestie. Bewerk de tekst en maak hem duidelijker!
Remove the front case cover to access components from the front of the device.
Secties
Stap 1 Front Case Cover  ¶
Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
  • Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
Stap 2  ¶
Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
Stap 2  ¶
  • Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
  • CAUTION: Do not fully remove the case cover until the next step has been completed or you may damage the ribbon cable. To be safe, only lift the cover high enough to fit a spudger in the gap.
Stap 3  ¶
Open the case cover starting on the side most distance from the buttons.
Stap 3  ¶
  • Open the case cover starting on the side most distance from the buttons.
Stap 4  ¶
Using a plastic opening tool, gently pry up on the top of where the ribbon cable attaches to the motherboard to release the cable.
Stap 4  ¶
  • Using a plastic opening tool, gently pry up on the top of where the ribbon cable attaches to the motherboard to release the cable.
Stap 5  ¶
You can now safely remove the front case cover from the device.
Stap 5  ¶
  • You can now safely remove the front case cover from the device.
