Help
Asus Eee PC 900 SSD Replacement
Replace the SSD in your Asus Eee PC 900.
  • Auteur: Brian Carreon
  • Geschatte tijd: 10 - 20 minuten
  • Moeilijkheid: Gemiddeld
The Asus Eee PC 900 uses a small solid state drive instead of a lrger hard drive. Use this guide to replace the SSD in the Asus Eee PC 900.
Stap 1 SSD  ¶
Remove the small sticker on the right side of the SSD/RAM compartment cover. Remove the two 4.76 mm Phillips #0 screws securing the SSD/RAM compartment cover. Remove the two 4.76 mm Phillips #0 screws securing the SSD/RAM compartment cover.
Stap 1 SSD  ¶
  • Remove the small sticker on the right side of the SSD/RAM compartment cover.
  • Remove the two 4.76 mm Phillips #0 screws securing the SSD/RAM compartment cover.
Stap 2  ¶
Using a plastic opening tool, lift up the bottom of the SSD/RAM compartment cover. Lift the cover away from the laptop.
Stap 2  ¶
  • Using a plastic opening tool, lift up the bottom of the SSD/RAM compartment cover.
  • Lift the cover away from the laptop.
Stap 3  ¶
Remove the two 4.76 mm Phillips #0 screws that secure the SSD. When the screws are removed, one end of the SSD should pop up. Slide the SSD out of its socket and lift it out of the compartment.
Stap 3  ¶
  • Remove the two 4.76 mm Phillips #0 screws that secure the SSD.
  • When the screws are removed, one end of the SSD should pop up.
  • Slide the SSD out of its socket and lift it out of the compartment.
