Help
Sansa e260R Rear Case Replacement
Replace the Rear panel on your Sansa e260R
  • Auteur: Casey Smith
  • Geschatte tijd: 5 - 10 minuten
  • Moeilijkheid: Gemiddeld
Stap 1 Rear Case  ¶
Before disassembling the device, make sure it is powered off.
Stap 1 Rear Case  ¶
  • Before disassembling the device, make sure it is powered off.
  • Remove the four 1.5mm screws on the back of the device.
Stap 2  ¶
Using a plastic opening tool, lift the metal backing from the front of the device.
Stap 2  ¶
  • Using a plastic opening tool, lift the metal backing from the front of the device.
Stap 3  ¶
Pull the rear panel off of the Sansa e260R.
Stap 3  ¶
  • Pull the rear panel off of the Sansa e260R.
