Ga door naar hoofdinhoud
Help
1998-2002 Honda Accord Tail Light Bulb Assemblies Replacement
Alleen vereisten
Alleen vereisten
Houd er rekening mee dat dit slechts een vereiste handleiding is voor andere handleidingen.
PRE-REQ
Stap 1 Tail Light Bulb Assemblies  ¶
Open the trunk using your key in the trunk key slot or by using the lever under the driver's console. Open the trunk using your key in the trunk key slot or by using the lever under the driver's console.
  • Open the trunk using your key in the trunk key slot or by using the lever under the driver's console.
Stap 2 Panel Tail Lights  ¶
Remove the small plastic screw along the vertical edge of the trunk entrance using a flathead screwdriver. Carefully peel back the trunk liner from around the edge of trunk opening by the light. Locate the two panel tail light connectors located between the liner and the panel tail light assembly.
  • Remove the small plastic screw along the vertical edge of the trunk entrance using a flathead screwdriver.
  • Carefully peel back the trunk liner from around the edge of trunk opening by the light.
  • Locate the two panel tail light connectors located between the liner and the panel tail light assembly.
Stap 3  ¶
Grab a light bulb socket and turn it counterclockwise until it can be removed from its hole. Repeat this process for the other light bulb socket. Repeat this process for the other light bulb socket.
Stap 3  ¶
  • Grab a light bulb socket and turn it counterclockwise until it can be removed from its hole.
  • Repeat this process for the other light bulb socket.
Stap 4 Trunk Lid Tail Lights  ¶
Locate the light bulb sockets in the trunk lid, located on the back side of the trunk tail lights. Turn the light bulb sockets counterclockwise and remove them from their holes. Turn the light bulb sockets counterclockwise and remove them from their holes.
  • Locate the light bulb sockets in the trunk lid, located on the back side of the trunk tail lights.
  • Turn the light bulb sockets counterclockwise and remove them from their holes.
