Ga door naar hoofdinhoud
Help
Nikon CoolPix S600 Lens Assembly Replacement
Heeft betere plaatjes nodig
Betere foto's zullen deze handleiding verbeteren. Help mee door het nemen, bewerken of uploaden van nieuwe foto's!
Ontbrekende vereisten
Deze handleiding heeft ontbrekende informatie over het starten van het proces. Maak een handleiding met de vereiste stappen!
Betere introductie
Betere introductie
Verbeter deze handleiding door het afmaken of herzien van de introductie.
Replace broken lens/shutter mechanism
Stap 1 Lens Assembly  ¶
From the top view of the camera, remove the one 5.8 mm screw. From the top view of the camera, remove the one 2.8 mm screw
  • From the top view of the camera, remove the one 5.8 mm screw.
  • From the top view of the camera, remove the one 2.8 mm screw
Stap 2  ¶
Remove the three 3.4 mm screws from the back side of the camera.
Stap 2  ¶
  • Remove the three 3.4 mm screws from the back side of the camera.
Stap 3  ¶
Remove the two 3.4 mm screws from the side of the camera.
Stap 3  ¶
  • Remove the two 3.4 mm screws from the side of the camera.
Stap 4  ¶
Separate the two metal body pieces from the rest of the camera.
Stap 4  ¶
  • Separate the two metal body pieces from the rest of the camera.
Stap 5  ¶
Gently remove the two ribbons connecting the lens to the mother board. Gently remove the two ribbons connecting the lens to the mother board.
Stap 5  ¶
  • Gently remove the two ribbons connecting the lens to the mother board.
Stap 6  ¶
Gently separate the camera lens from the mother board. Gently separate the camera lens from the mother board.
Stap 6  ¶
  • Gently separate the camera lens from the mother board.
