Ga door naar hoofdinhoud
Help
iPad 2 CDMA Headphone Jack Replacement
Replace the headphone jack in your iPad 2 CDMA.
Use this guide to replace a broken headphone jack.
Parts of this guide were shot with a Wi-Fi model and as such the internals may look slightly different from the cellular model. The procedure is the same for both models except where noted.
Stap 1 Headphone Jack  ¶
Use the edge of a plastic opening tool to disconnect the microphone cable connector.
  • Use the edge of a plastic opening tool to disconnect the microphone cable connector.
Stap 2  ¶
Remove the headphone jack from the iPad 2.
Stap 2  ¶
  • Remove the headphone jack from the iPad 2.
