Ga door naar hoofdinhoud
Help
Dell Dimension 4600 RAM Replacement
Uitgelichte handleiding
De iFixit-werknemers vonden deze handleiding uitzonderlijk cool.
This guide covers the removal of the RAM modules from your computer.
  • Auteur: Daniel Crawford
  • Geschatte tijd: 10 minuten
  • Moeilijkheid: Eenvoudig
Use this guide to replace the RAM in your Dell Dimension 4600.
Secties
Relevante Onderdelen
Stap 1 RAM  ¶
Lay the computer flat on its side so that you are looking down on all of the components.
Stap 1 RAM  ¶
  • Lay the computer flat on its side so that you are looking down on all of the components.
  • Locate the RAM modules on the motherboard.
Stap 2  ¶
Locate the white or black tabs holding the RAM module in place. Place your index finger on the tab and firmly press down. The tab should release and the RAM module should be slightly raised.
Stap 2  ¶
  • Locate the white or black tabs holding the RAM module in place.
  • Place your index finger on the tab and firmly press down. The tab should release and the RAM module should be slightly raised.
  • Repeat this for the tab on the other side of the RAM module.
  • Repeat this step for each RAM module.
Stap 3  ¶
Grasp the RAM module and firmly pull upwards until it is released from its slot. Repeat this step for each RAM module.
Stap 3  ¶
  • Grasp the RAM module and firmly pull upwards until it is released from its slot.
