Ga door naar hoofdinhoud
Help
Macintosh PowerBook 165c Modem Card Replacement
This guide will demonstrate how to replace the Macintosh PowerBook 165c Modem Card.
  • Auteur: John
  • Geschatte tijd: 15 - 20 minuten
  • Moeilijkheid: Gemiddeld
Use this guide to replace the Modem Card.
Secties
Stap 1 Modem Card  ¶
Orient the computer so the ports are facing you.
Stap 1 Modem Card  ¶
  • Orient the computer so the ports are facing you.
Stap 2  ¶
Locate the Modem Card on the lower case. Use a T8 torx screwdriver to remove the two, 7.7mm long screws from the two corners.
Stap 2  ¶
  • Locate the Modem Card on the lower case.
  • Use a T8 torx screwdriver to remove the two, 7.7mm long screws from the two corners.
  • The modem card is an optional component on the Macintosh 165c, and may not be included in all devices.
Stap 3  ¶
Lift the modem card directly upward until it releases from the connector.
Stap 3  ¶
  • Lift the modem card directly upward until it releases from the connector.
  • If the modem card is difficult to remove, gently jostle it back and forth as you lift up.
