Ga door naar hoofdinhoud
Help
Nikon CoolPix S600 Front and Rear Casing Replacement
Heeft betere plaatjes nodig
Betere foto's zullen deze handleiding verbeteren. Help mee door het nemen, bewerken of uploaden van nieuwe foto's!
Ontbrekende vereisten
Deze handleiding heeft ontbrekende informatie over het starten van het proces. Maak een handleiding met de vereiste stappen!
Betere introductie
Betere introductie
Verbeter deze handleiding door het afmaken of herzien van de introductie.
How to remove the camera's case to access the internal parts of the camera
Stap 1 Front and Rear Casing  ¶
With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
Stap 2  ¶
Remove the chrome side cover from the body of the camera.
Stap 2  ¶
  • Remove the chrome side cover from the body of the camera.
Stap 3  ¶
Remove the four 3.2 mm screws on the bottom of the camera.
Stap 3  ¶
  • Remove the four 3.2 mm screws on the bottom of the camera.
Stap 4  ¶
Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward) Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
Stap 4  ¶
  • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
  • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
Stap 5  ¶
Gently separate the back cover from the body of the camera. The back casing will still be connected to the circuit board by a ribbon
Stap 5  ¶
  • Gently separate the back cover from the body of the camera.
  • The back casing will still be connected to the circuit board by a ribbon
Stap 6  ¶
Use the tweezers to disconnect the ribbon from the circuit board.
Stap 6  ¶
  • Use the tweezers to disconnect the ribbon from the circuit board.
Stap 7  ¶
Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
Stap 7  ¶
  • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
Stap 8  ¶
Gently separate the front cover from the body of the camera. The front casing will still be connected to the circuit board by a few wires
Stap 8  ¶
  • Gently separate the front cover from the body of the camera.
  • The front casing will still be connected to the circuit board by a few wires
Stap 9  ¶
Remove the two 3.2 mm screws that hold the flash to the front cover.
Stap 9  ¶
  • Remove the two 3.2 mm screws that hold the flash to the front cover.
Stap 10  ¶
Use the Spudger to remove the copper colored light bulb clip. Remove the front cover entierly from the camera body. Remove the front cover entierly from the camera body.
Stap 10  ¶
  • Use the Spudger to remove the copper colored light bulb clip.
  • Remove the front cover entierly from the camera body.
