Ga door naar hoofdinhoud
Help
TiVo Series 2 TCD24008A Motherboard Replacement
This guide will teach you how to detach the motherboard from the device.
  • Auteur: Cody Hunter
  • Geschatte tijd: 15 - 30 minuten
  • Moeilijkheid: Gemiddeld
The Motherboard contains all the 'brains' of the device. In case this component needs to be replaced, this guide will walk you through the installation of the motherboard.
Stap 1 Motherboard  ¶
Unscrew the 0.31 inch T-9 size screw on the back panel
  • Unscrew the 0.31 inch T-9 size screw on the back panel
  • Unscrew the two 0.59 inch T-8 size screws on the back panel
Stap 2  ¶
Unplug the fan from the motherboard by gently pulling up on the red plug.
Stap 2  ¶
  • Unplug the fan from the motherboard by gently pulling up on the red plug.
Stap 3  ¶
Unplug the ribbon attaching the front panel sensor by pulling it upwards gently.
Stap 3  ¶
  • Unplug the ribbon attaching the front panel sensor by pulling it upwards gently.
Stap 4  ¶
Unplug the ribbon connecting the hard drive to the motherboard by pulling straight up on the ribbon. This may require some gentle wiggling.
Stap 4  ¶
  • Unplug the ribbon connecting the hard drive to the motherboard by pulling straight up on the ribbon. This may require some gentle wiggling.
Stap 5  ¶
Unplug the ribbon connecting the power supply to the motherboard by pulling upwards on this ribbon.
Stap 5  ¶
  • Unplug the ribbon connecting the power supply to the motherboard by pulling upwards on this ribbon.
Stap 6  ¶
Locate the four metal tabs on the motherboard. Using Pliers, bend each of the tabs until they align straight with the holes underneath them.
Stap 6  ¶
  • Locate the four metal tabs on the motherboard.
  • Using Pliers, bend each of the tabs until they align straight with the holes underneath them.
  • Bend these just enough to slip them through the holes. Over-bending could snap these tabs. While this won't affect how the TiVo functions, they are there to secure the motherboard to prevent damage.
Stap 7  ¶
Locate and remove the four 0.31 inch T-9 size screws at the front of the motherboard.
Stap 7  ¶
  • Locate and remove the four 0.31 inch T-9 size screws at the front of the motherboard.
Stap 8  ¶
Pull directly up on the motherboard so that it slips over the four golden metal tabs. Pull up and away from the back panel so all of the cable inputs slip through the casing.
Stap 8  ¶
  • Pull directly up on the motherboard so that it slips over the four golden metal tabs.
  • Pull up and away from the back panel so all of the cable inputs slip through the casing.
