Ga door naar hoofdinhoud
Help
Samsung Galaxy Tab 7.0 Volume Buttons Replacement
Replace the volume buttons on your Samsung Galaxy Tab.
Use this guide to replace the volume buttons.
Secties
Gereedschap
Stap 1 Volume Buttons  ¶
Use the edge of a plastic opening tool to pry the volume buttons connector straight up from its socket on the motherboard.
  • Use the edge of a plastic opening tool to pry the volume buttons connector straight up from its socket on the motherboard.
Stap 2  ¶
Insert the edge of a plastic opening tool in between the inner framework and the volume button recess. Carefully run the plastic opening tool to the left to dislodge the volume buttons assembly from the inner framework.
Stap 2  ¶
  • Insert the edge of a plastic opening tool in between the inner framework and the volume button recess.
  • Carefully run the plastic opening tool to the left to dislodge the volume buttons assembly from the inner framework.
Stap 3  ¶
Remove the volume buttons assembly away from the Galaxy Tab.
Stap 3  ¶
  • Remove the volume buttons assembly away from the Galaxy Tab.
