Ga door naar hoofdinhoud
Help
MacBook Air 13" Mid 2011 I/O Board Replacement
Replace the I/O board on your MacBook Air 13" Mid 2011. The I/O board houses the MagSafe DC-in port, a USB socket, and the headphone jack.
  • Auteur: Andrew Bookholt
  • Geschatte tijd: 30 - 45 minuten
  • Moeilijkheid: Gemiddeld
Use this guide to replace your Air's I/O board which houses the MagSafe DC-in port, a USB socket, and the headphone jack.
Gereedschap (wordt vervolgd)
Relevante Onderdelen
Stap 1 I/O Board  ¶
Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
Stap 1 I/O Board  ¶
  • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
  • Pull the cable parallel to the face of the logic board toward the right edge of the Air.
Stap 2  ¶
Pull the camera cable parallel to the face of the I/O board toward the corner of the Air to disconnect it from its socket, using the tip of a spudger to help push the connector out of its socket.
Stap 2  ¶
  • Pull the camera cable parallel to the face of the I/O board toward the corner of the Air to disconnect it from its socket, using the tip of a spudger to help push the connector out of its socket.
  • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
Stap 3  ¶
Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board. Pry up from beneath the wires.
Stap 3  ¶
  • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
  • Pry up from beneath the wires.
  • De-route the left speaker cable from its retainer on the I/O board.
Stap 4  ¶
Use the flat end of a spudger to pry the microphone cable connector up and out of its socket on the I/O board.
Stap 4  ¶
  • Use the flat end of a spudger to pry the microphone cable connector up and out of its socket on the I/O board.
Stap 5  ¶
Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
Stap 5  ¶
  • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
Stap 6  ¶
Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
Stap 6  ¶
  • Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
