Ga door naar hoofdinhoud
Help
MacBook Air 13" Mid 2011 Fan Replacement
Replace a dead fan on your MacBook Air 13" Mid 2011.
Use this guide to replace a dead or noisy fan.
Gereedschap (wordt vervolgd)
Relevante Onderdelen
Stap 1 Fan  ¶
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Stap 1 Fan  ¶
  • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
Stap 2  ¶
Peel the rubber gasket off the adhesive on the top of the fan.
Stap 2  ¶
  • Peel the rubber gasket off the adhesive on the top of the fan.
Stap 3  ¶
Remove the following three screws securing the fan to the upper case:
Stap 3  ¶
  • Remove the following three screws securing the fan to the upper case:
  • One 3.6 mm T5 Torx screw
  • One 2.7 mm T5 Torx screw
  • One 3.6 mm T5 Torx screw with a short head
Stap 4  ¶
Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
Stap 4  ¶
  • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
