Ga door naar hoofdinhoud
Help
MacBook Air 11" Mid 2011 Lower Case Replacement
Replace the lower case on your MacBook Air 11" Mid 2011.
Use this guide to remove the lower case.
Stap 1 Lower Case  ¶
Shut down and close your computer. Lay it on a soft surface top-side down.
Stap 1 Lower Case  ¶
  • Shut down and close your computer. Lay it on a soft surface top-side down.
  • Remove the following ten screws:
  • Two 8 mm 5-point Pentalobe screws
  • Eight 2.5 mm 5-point Pentalobe screws
  • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
Stap 2  ¶
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Stap 2  ¶
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
