Ga door naar hoofdinhoud
Help
HP TouchPad LCD Replacement
Replace the LCD on your HP TouchPad.
Use this guide to replace a broken LCD.
Secties
Stap 1 LCD  ¶
Use the edge of a plastic opening tool to peel up the self-adhesive pull tab stuck to the display data cable.
Stap 1 LCD  ¶
  • Use the edge of a plastic opening tool to peel up the self-adhesive pull tab stuck to the display data cable.
Stap 2  ¶
Pull the tab up and toward the middle of the display to unlock the display data cable connector from its socket on the LCD. Pull the display data cable out of its socket on the LCD and set it aside.
Stap 2  ¶
  • Pull the tab up and toward the middle of the display to unlock the display data cable connector from its socket on the LCD.
  • Pull the display data cable out of its socket on the LCD and set it aside.
  • Do not lift upward on the connector as you pull it out of its socket. Pull the connector parallel to the face of the LCD.
Stap 3  ¶
LCD remains.
Stap 3  ¶
  • LCD remains.
