Ga door naar hoofdinhoud
Help
iMac Intel 21.5" EMC 2428 Left Speaker Replacement
Replace a blown left speaker in your iMac Intel 21.5" EMC 2428.
Use this guide to replace a blown left speaker.
Secties
Stap 1 Left Speaker  ¶
Pull the left speaker cables out from under the strip of tape securing them to the outer case.
  • Pull the left speaker cables out from under the strip of tape securing them to the outer case.
Stap 2  ¶
Remove the single 13 mm T10 Torx screw securing the left speaker to the outer case.
Stap 2  ¶
  • Remove the single 13 mm T10 Torx screw securing the left speaker to the outer case.
Stap 3  ¶
Use the flat end of a spudger to pry the left side of the left speaker away from the side of the outer case.
Stap 3  ¶
  • Use the flat end of a spudger to pry the left side of the left speaker away from the side of the outer case.
Stap 4  ¶
Pull the left speaker toward the center of the iMac to dislodge it from the corner of the outer case. This will require a bit of force.
Stap 4  ¶
  • Pull the left speaker toward the center of the iMac to dislodge it from the corner of the outer case.
  • This will require a bit of force.
  • Remove the left speaker from the outer case.
