Ga door naar hoofdinhoud
Help
Apple Powerbook 520 Floppy Drive Replacement
Ontbrekende vereisten
Deze handleiding heeft ontbrekende informatie over het starten van het proces. Maak een handleiding met de vereiste stappen!
Stappen inkorten
Stappen inkorten
Deze handleiding heeft onnodige stappen. Kort ze in om beknopter te kunnen zijn!
This guide will serve as a reference to accessing and replacing the 3.5" floppy drive.
This repair will need:
A T8 Torx Screwdriver.
Stap 1 Floppy Drive  ¶
With the Generally Disassembly completed, you may proceed to floppy drive installation.
  • With the Generally Disassembly completed, you may proceed to floppy drive installation.
Stap 2  ¶
Remove the plastic panel at the bottom of the display.
Stap 2  ¶
  • Remove the plastic panel at the bottom of the display.
Stap 3  ¶
Reverse the computer to access the peripheral panel in the back.
Stap 3  ¶
  • Reverse the computer to access the peripheral panel in the back.
  • Remove the two T8 Torx screws on either side of the bar code panel.
Stap 4  ¶
Reverse the computer to have the monitor and mousepad facing you.
Stap 4  ¶
  • Reverse the computer to have the monitor and mousepad facing you.
  • Remove the plastic panel underneath the display.
Stap 5  ¶
Remove the three T8 Torx screws securing the floppy drive to the frame.
Stap 5  ¶
  • Remove the three T8 Torx screws securing the floppy drive to the frame.
Stap 6  ¶
Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
Stap 6  ¶
  • Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
Stap 7  ¶
Lift the defective floppy drive from the body of the computer.
Stap 7  ¶
  • Lift the defective floppy drive from the body of the computer.
Stap 8  ¶
Replace the defective drive with a new drive.
Stap 8  ¶
  • Replace the defective drive with a new drive.
  • Follow these instructions in reverse order to reassemble the device.
