Ga door naar hoofdinhoud
Help
Canon Powershot S200 Screen Replacement
Heeft betere plaatjes nodig
Betere foto's zullen deze handleiding verbeteren. Help mee door het nemen, bewerken of uploaden van nieuwe foto's!
Opsommingstekens!
Opsommingstekens!
Betere coördinatie met markeringen en kleur/type bullet points om deze handleiding nog duidelijker te maken!
A step-by-step guide on how to repair a Canon Powershot S200 screen
  • Auteur: Anh
  • Geschatte tijd: 30 - 40 minuten
  • Moeilijkheid: Moeilijk
The screen is a crucial part of the camera: it displays images for consumers to view their pictures instantly. Damage to the screen may require replacement.
Secties
Gereedschap
Stap 1 Screen  ¶
After completing the removal of the motherboard, remove the tripod mounting screws (3.4mm) on the left side
Stap 1 Screen  ¶
  • After completing the removal of the motherboard, remove the tripod mounting screws (3.4mm) on the left side
Stap 2  ¶
Carefully pry the left side of the housing plate from the bottom of the tripod mounting plate, releasing it from the two alignment pegs next to the screws
Stap 2  ¶
  • Carefully pry the left side of the housing plate from the bottom of the tripod mounting plate, releasing it from the two alignment pegs next to the screws
Stap 3  ¶
Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
Stap 3  ¶
  • Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
  • Be careful because there are still wire connections attached to the mounting plate which you don't want to remove
Stap 4  ¶
Remove the 2.1mm screws from the bottom and top of the screen connecting it to the housing plate
Stap 4  ¶
  • Remove the 2.1mm screws from the bottom and top of the screen connecting it to the housing plate
Stap 5  ¶
Unsolder the four points at the top of the screen with a soldering iron
Stap 5  ¶
  • Unsolder the four points at the top of the screen with a soldering iron
