Help
Apple PowerBook G3 400 Display Replacement
This repair guide will teach and show you how to replace the display.
  • Auteur: Isabelle
  • Moeilijkheid: Gemiddeld
You will do this after you have taken out the hard drive.
Secties
Stap 1 Display  ¶
Your computer will look approximately like this.
Stap 1 Display  ¶
  • Your computer will look approximately like this.
Stap 2  ¶
Push the display back.
Stap 2  ¶
  • Push the display back.
  • Put your index finger under the power button and gently pull the clutch cover back.
  • Repeat for the left side.
Stap 3  ¶
Lift the clutch cover up and off.  Pull it towards yourself.
Stap 3  ¶
  • Lift the clutch cover up and off. Pull it towards yourself.
Stap 4  ¶
Disconnect the display cable from the logic board.
Stap 4  ¶
  • Disconnect the display cable from the logic board.
Stap 5  ¶
Remove the Torx screw that holds the display cable.
Stap 5  ¶
  • Remove the Torx screw that holds the display cable.
  • Pull out thick display inverter board by pulling it up and out. Two tabs will be holding it in place, you need to get pass these to pull the board free.
Stap 6  ¶
Disconnect the white inverter cable.  Pull it towards the left.
Stap 6  ¶
  • Disconnect the white inverter cable. Pull it towards the left.
Stap 7  ¶
Disconnect the inverter plug by pulling it up from the logib board.
Stap 7  ¶
  • Disconnect the inverter plug by pulling it up from the logib board.
Stap 8  ¶
Turn the laptop around.
Stap 8  ¶
  • Turn the laptop around.
  • Open the port door.
  • Remove the four Torx screws.
Stap 9  ¶
Turn the laptop so the front faces you.
Stap 9  ¶
  • Turn the laptop so the front faces you.
  • Pull the black Airport antenna up.
Stap 10  ¶
Pull the display up as you hold it firmly with both hands.
Stap 10  ¶
  • Pull the display up as you hold it firmly with both hands.
