Help
Canon PowerShot A550 LCD Screen Replacement
This repair guide will teach you how to replace a broken LCD Screen in your Canon PowerShot A550.
  • Auteur: Precilla Tang
  • Geschatte tijd: 15 - 20 minuten
  • Moeilijkheid: Gemiddeld
The Canon PowerShot A550 features a 2.0 inch low-temperature polycrystalline silicon TFT color LCD screen with 86,000 megapixels. This component is necessary for photographing and viewing your pictures. This guide will teach you how to replace your LCD screen if it becomes broken or cracked.
Stap 1 LCD Screen  ¶
Use a #00 phillips head screwdriver to remove 2 3.34mm phillips screws holding the LCD screen in place.
Stap 1 LCD Screen  ¶
  • Use a #00 phillips head screwdriver to remove 2 3.34mm phillips screws holding the LCD screen in place.
Stap 2  ¶
Use an iPod Opening Tool to lift the brown portion of the connector to unlock it. Slide the data cable out of the connector.
Stap 2  ¶
  • Use an iPod Opening Tool to lift the brown portion of the connector to unlock it.
  • Slide the data cable out of the connector.
  • Caution: Do not force the data cable out of the connector. It may rip!
Stap 3  ¶
The LCD screen can now be be removed to be fixed/replaced.
Stap 3  ¶
  • The LCD screen can now be be removed to be fixed/replaced.
