Ga door naar hoofdinhoud
Help
iMac Intel 21.5" EMC 2428 RAM Replacement
Uitgelichte handleiding
De iFixit-werknemers vonden deze handleiding uitzonderlijk cool.
Replace the RAM in your iMac Intel 21.5" EMC 2428.
  • Auteur: Walter Galan
  • Geschatte tijd: 5 - 15 minuten
  • Moeilijkheid: Eenvoudig
Use this guide to upgrade your RAM for an instant increase in speed.
Secties
Gereedschap
Stap 1 RAM  ¶
Gently slide the black plastic RAM pull tab out from the RAM slot. Pull the black plastic tab away from the bottom edge of the iMac to eject the module(s) on that side of the RAM bay. This may require a bit of force.
Stap 1 RAM  ¶
  • Gently slide the black plastic RAM pull tab out from the RAM slot.
  • Pull the black plastic tab away from the bottom edge of the iMac to eject the module(s) on that side of the RAM bay.
  • This may require a bit of force.
Stap 2  ¶
Slide the old RAM module(s) out of their slots in the RAM bay and set them aside.
Stap 2  ¶
  • Slide the old RAM module(s) out of their slots in the RAM bay and set them aside.
Stap 3  ¶
Repeat the process in the previous steps to remove the RAM module(s) from the other side of the RAM bay. Repeat the process in the previous steps to remove the RAM module(s) from the other side of the RAM bay. Repeat the process in the previous steps to remove the RAM module(s) from the other side of the RAM bay.
Stap 3  ¶
  • Repeat the process in the previous steps to remove the RAM module(s) from the other side of the RAM bay.
Stap 4  ¶
When installing new RAM modules, it is important to orient them correctly. Be sure the small notch cut into each RAM module (shown in the first picture) mates with the protrusion in each RAM slot (shown in the second picture). Your iMac has four RAM slots. Be sure to slide each RAM module into its slot horizontally. This will prevent getting the modules stuck between two of the adjacent slots.
Stap 4  ¶
  • When installing new RAM modules, it is important to orient them correctly.
  • Be sure the small notch cut into each RAM module (shown in the first picture) mates with the protrusion in each RAM slot (shown in the second picture).
  • Your iMac has four RAM slots. Be sure to slide each RAM module into its slot horizontally. This will prevent getting the modules stuck between two of the adjacent slots.
  • Once you have oriented the new RAM modules correctly, gently slide them completely into the iMac and use your thumbs to firmly seat them in their sockets.
