Ga door naar hoofdinhoud
Help
HTC HD2 Phone Speaker Replacement
Ontbrekende vereisten
Deze handleiding heeft ontbrekende informatie over het starten van het proces. Maak een handleiding met de vereiste stappen!
The speaker Is easily removed once the chassis has been taken off of the phone
This guide will help you get to the speaker, in case it needs to be replaced
Secties
Stap 1 Phone Speaker  ¶
With the chassis removed, set down the phone and locate the speaker on the inside of the housing.
  • With the chassis removed, set down the phone and locate the speaker on the inside of the housing.
  • The speaker should be easily popped out of place with a small amount of force
Stap 2  ¶
Congratulations! The speaker is now removed and can be replaced or repaired.
Stap 2  ¶
  • Congratulations! The speaker is now removed and can be replaced or repaired.
