Help
Apple Powerbook 5300 Battery Replacement
Actiemomenten
Actiemomenten
Wees een actieheld! Deze handleiding heeft plaatjes nodig die beter tonen hoe specifieke handelingen uitgevoerd moeten worden.
Installing/replacing a Powerbook 5300 battery.
  • Auteur: Alex Wineteer
  • Geschatte tijd: 1 minuut
  • Moeilijkheid: Zeer eenvoudig
This guide will show you how to install a Powerbook 5300 battery.
Stap 1 Battery  ¶
Position the Powerbook towards you with the monitor closed.
Stap 1 Battery  ¶
  • Position the Powerbook towards you with the monitor closed.
  • Press the battery removal latch located on the right side of the front panel.
  • Gently slide the battery out.
  • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
