Ga door naar hoofdinhoud
Help
Nintendo 3DS Lower Case Replacement
Lower case removal.
  • Auteur: David Hodson
  • Geschatte tijd: 10 - 25 minuten
  • Moeilijkheid: Gemiddeld
Remove your broken Nintendo 3DS lower case and replace it with a fresh one.
Stap 1 Lower Case  ¶
Remove the nine 6.3 mm black Phillips screws from the lower case.
Stap 1 Lower Case  ¶
  • Remove the nine 6.3 mm black Phillips screws from the lower case.
  • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Stap 2  ¶
Lift the bottom edge of the lower case off the rest of the 3DS. There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off. Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
Stap 2  ¶
  • Lift the bottom edge of the lower case off the rest of the 3DS.
  • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
  • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
  • Remove the lower case from the device.
