Help
Nikon Coolpix S220 Accessing the Motherboard
This guide will teach the reader how to access the motherboard.
  • Auteur: Shauna
  • Geschatte tijd: 10 - 15 minuten
  • Moeilijkheid: Gemiddeld
This guide will show how to access the motherboard which will give you the ability to remove the lens and flash.
Secties
Gereedschap
Stap 1 Motherboard  ¶
Remove the four 3.8 mm screws located near the bottom right and top left of the LCD base plate.
  • Remove the four 3.8 mm screws located near the bottom right and top left of the LCD base plate.
Stap 2  ¶
Lift up silver LCD base plate
Stap 2  ¶
  • Lift up silver LCD base plate
Stap 3  ¶
Using tweezers, lift up the retaining flap on the ZIF connector securing the button panel ribbon cable. Slide the button panel ribbon cable out of its socket on the motherboard.
Stap 3  ¶
  • Using tweezers, lift up the retaining flap on the ZIF connector securing the button panel ribbon cable.
  • Slide the button panel ribbon cable out of its socket on the motherboard.
