Help
HP Pavilion dv1000 Back Cover Replacement
Heeft betere plaatjes nodig
Betere foto's zullen deze handleiding verbeteren. Help mee door het nemen, bewerken of uploaden van nieuwe foto's!
Stappen inkorten
Stappen inkorten
Deze handleiding heeft onnodige stappen. Kort ze in om beknopter te kunnen zijn!
This guide will show how to remove the back cover from the laptop in order to access the parts inside the computer.
  • Auteur: Ross Johnson
  • Geschatte tijd: 10 minuten
  • Moeilijkheid: Gemiddeld
The back cover must first be removed before the CD drive, fan, and heat sink can be removed.
Secties
Stap 1 Back Cover  ¶
Remove and set aside all of the highlighted screws in the first picture with a #00 Phillips screwdriver. Remove and separately set aside all of the highlighted screws in the second picture with a #00 Phillips screwdriver.
Stap 1 Back Cover  ¶
  • Remove and set aside all of the highlighted screws in the first picture with a #00 Phillips screwdriver.
  • Remove and separately set aside all of the highlighted screws in the second picture with a #00 Phillips screwdriver.
  • Caution: There are two more screws to remove, so do not try and remove the back cover yet.
Stap 2  ¶
Turn the laptop right side up, and open it to reveal the keyboard. The keyboard should lift up and out easily, but be careful because it is attached to the computer by a ribbon cable. Press the two white clips forward and lift the tape out of the clip.
Stap 2  ¶
  • Turn the laptop right side up, and open it to reveal the keyboard.
  • The keyboard should lift up and out easily, but be careful because it is attached to the computer by a ribbon cable.
  • Press the two white clips forward and lift the tape out of the clip.
Stap 3  ¶
Locate the MediaKeys. They are the black strip right above where the keyboard was. Using the spudger, gently pry up the MediaKeys.
Stap 3  ¶
  • Locate the MediaKeys. They are the black strip right above where the keyboard was.
  • Using the spudger, gently pry up the MediaKeys.
  • If you feel any resistance, stop and check you have removed all of the screws from the battery compartment.
Stap 4  ¶
Remove the two screws next to the left hinge of the monitor with a #00 Phillips screwdriver. Keep these screws separate from the other screws you have removed.
Stap 4  ¶
  • Remove the two screws next to the left hinge of the monitor with a #00 Phillips screwdriver.
  • Keep these screws separate from the other screws you have removed.
Stap 5  ¶
Using the spudger, loosen the casing behind the battery and the two sides. The case should lift easily upwards and outwards towards you if you are facing the battery compartment.
Stap 5  ¶
  • Using the spudger, loosen the casing behind the battery and the two sides.
  • The case should lift easily upwards and outwards towards you if you are facing the battery compartment.
  • Make sure the cord that was attached to the Bluetooth cable is not still threaded through the case when trying to remove it.
  • If you feel any resistance, stop. Do not force anything. Go back through the steps and make sure you loosened everything.
