Ga door naar hoofdinhoud
Help
HP Photosmart D110a LCD Screen Replacement
Actiemomenten
Actiemomenten
Wees een actieheld! Deze handleiding heeft plaatjes nodig die beter tonen hoe specifieke handelingen uitgevoerd moeten worden.
Stappen inkorten
Stappen inkorten
Deze handleiding heeft onnodige stappen. Kort ze in om beknopter te kunnen zijn!
Verwarrende Tekst
Verwarrende Tekst
Een deel van de tekst in deze handleiding is verwarrend, dubbelop of naast de kwestie. Bewerk de tekst en maak hem duidelijker!
Considering the steps in this guide were completed by 2 people, it is recommended to attempt this guide with 2 or more people.
Required Tools
  • T-9 Screwdriver
  • Needle-Nose Pliers
Stap 1 LCD Screen  ¶
The LCD screen is attached to the piece of the hood with the glass shield. Two ribbon wires are connected to the LCD module. The smaller of the two cannot be removed. Do not remove the small ribbon wire.
Stap 1 LCD Screen  ¶
  • The LCD screen is attached to the piece of the hood with the glass shield.
  • Two ribbon wires are connected to the LCD module. The smaller of the two cannot be removed. Do not remove the small ribbon wire.
  • The LCD is attached to the hood by two slots as shown in red. Push the sloped slides of the slots inward to release the slots from the hood.
Stap 2  ¶
Push the LCD module down and pull it away from the hood. The LCD should slide out of its holders. The LCD module should now be separated from the hood. The large ribbon wire from the LCD can be detached if needed. The LCD module should now be separated from the hood. The large ribbon wire from the LCD can be detached if needed.
Stap 2  ¶
  • Push the LCD module down and pull it away from the hood. The LCD should slide out of its holders.
  • The LCD module should now be separated from the hood. The large ribbon wire from the LCD can be detached if needed.
