Ga door naar hoofdinhoud
Help
MacBook Core 2 Duo Bluetooth Board Replacement
  • Auteur: iRobot
  • Moeilijkheid: Moeilijk
Replace the Bluetooth board.
Stap 1 Bluetooth Board  ¶
Use a spudger to disconnect the gold Bluetooth antenna connector from the Bluetooth board.
  • Use a spudger to disconnect the gold Bluetooth antenna connector from the Bluetooth board.
Stap 2  ¶
Pry the Bluetooth board up from the lower case.
Stap 2  ¶
  • Pry the Bluetooth board up from the lower case.
Stap 3  ¶
Peel back the orange tape covering the Bluetooth board so you can access the data cable connector.
Stap 3  ¶
  • Peel back the orange tape covering the Bluetooth board so you can access the data cable connector.
  • Disconnect the data cable from the Bluetooth board.
  • Lift the Bluetooth board out of the computer.
