Help
MacBook Pro 13" Unibody Early 2011 Microphone Replacement
Replace the microphone in your Early 2011 MacBook Pro 13" Unibody.
  • Auteur: Andrew Bookholt
  • Geschatte tijd: 45 minuten - 2 uren
  • Moeilijkheid: Moeilijk
Use this guide to replace a broken microphone.
Secties
Gereedschap
Stap 1 Microphone  ¶
De-route the microphone cable from the channel molded into the left speaker housing.
Stap 1 Microphone  ¶
  • De-route the microphone cable from the channel molded into the left speaker housing.
Stap 2  ¶
Remove the small piece of black tape covering the microphone connector.
Stap 2  ¶
  • Remove the small piece of black tape covering the microphone connector.
Stap 3  ¶
Use the flat end of a spudger to pry the microphone connector up from its socket on the logic board.
Stap 3  ¶
  • Use the flat end of a spudger to pry the microphone connector up from its socket on the logic board.
  • Pry up from beneath the wires.
Stap 4  ¶
Remove the microphone from the logic board.
Stap 4  ¶
  • Remove the microphone from the logic board.
