Ga door naar hoofdinhoud
Help
MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Board Replacement
Replace the AirPort and Bluetooth board on your Early 2011 MacBook Pro 13" Unibody.
  • Auteur: Andrew Bookholt
  • Geschatte tijd: 20 - 30 minuten
  • Moeilijkheid: Gemiddeld
Use this guide to replace a broken AirPort/Bluetooth board.
Stap 1 AirPort/Bluetooth Board  ¶
Peel back the piece of EMI tape covering the AirPort/Bluetooth cable connector.
  • Peel back the piece of EMI tape covering the AirPort/Bluetooth cable connector.
Stap 2  ¶
Use the tip of a spudger to lift the AirPort/Bluetooth cable connector out of its socket on the AirPort/Bluetooth board. Remove the AirPort/Bluetooth cable.
Stap 2  ¶
  • Use the tip of a spudger to lift the AirPort/Bluetooth cable connector out of its socket on the AirPort/Bluetooth board.
  • Remove the AirPort/Bluetooth cable.
Stap 3  ¶
Continue peeling the EMI tape off the bottom of the AirPort/Bluetooth bracket and remove it from the assembly.
Stap 3  ¶
  • Continue peeling the EMI tape off the bottom of the AirPort/Bluetooth bracket and remove it from the assembly.
Stap 4  ¶
Remove the three 3 mm Phillips screws securing the AirPort/Bluetooth board to its bracket.
Stap 4  ¶
  • Remove the three 3 mm Phillips screws securing the AirPort/Bluetooth board to its bracket.
Stap 5  ¶
Remove the AirPort/Bluetooth board from its bracket.
Stap 5  ¶
  • Remove the AirPort/Bluetooth board from its bracket.
  • Be careful not to damage the pink thermal pad attached to the bracket.
