Help
iPhone 4 (CDMA/Verizon) Screen Replacement
Uitgelichte handleiding
De iFixit-werknemers vonden deze handleiding uitzonderlijk cool.
Replace a cracked front panel or a broken display on your CDMA/Verizon iPhone 4.
  • Auteur: Andrew Bookholt
  • Geschatte tijd: 1 - 3 uren
  • Moeilijkheid: Moeilijk
Use this guide to replace a broken screen for your iPhone 4.
After successfully replacing the screen, protect your new display from scratches by installing a screen protector.
Secties
Gereedschap
Stap 1 Screen  ¶
Remove the two 2.4 mm Phillips screws from the sides of the speaker enclosure assembly.
Stap 1 Screen  ¶
  • Remove the two 2.4 mm Phillips screws from the sides of the speaker enclosure assembly.
Stap 2  ¶
Remove the small plastic bracket that was installed under the screw closest to the dock connector cable.
Stap 2  ¶
  • Remove the small plastic bracket that was installed under the screw closest to the dock connector cable.
Stap 3  ¶
Remove the speaker enclosure assembly from the iPhone. Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the second picture.
Stap 3  ¶
  • Remove the speaker enclosure assembly from the iPhone.
  • Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the second picture.
  • Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
Stap 4  ¶
Remove the small pieces of black tape covering the display mounting tabs.
Stap 4  ¶
  • Remove the small pieces of black tape covering the display mounting tabs.
Stap 5  ¶
Remove the 1.6 mm Phillips screw securing the display assembly near the power button.
Stap 5  ¶
  • Remove the 1.6 mm Phillips screw securing the display assembly near the power button.
Stap 6  ¶
Remove the 1.6 mm Phillips screw near the headphone jack.
Stap 6  ¶
  • Remove the 1.6 mm Phillips screw near the headphone jack.
Stap 7  ¶
Remove the 1.6 mm Phillips screw near the lower microphone.
Stap 7  ¶
  • Remove the 1.6 mm Phillips screw near the lower microphone.
Stap 8  ¶
Remove the 1.6 mm Phillips screw near the dock connector cable.
Stap 8  ¶
  • Remove the 1.6 mm Phillips screw near the dock connector cable.
Stap 9  ¶
Loosen the three large-headed Phillips screws along the volume button side of the iPhone about one half turn. It is not necessary to completely remove these screws. When reinstalling the display assembly, be sure the washers are closest to the screw head (as seen in the second picture).
Stap 9  ¶
  • Loosen the three large-headed Phillips screws along the volume button side of the iPhone about one half turn.
  • It is not necessary to completely remove these screws. When reinstalling the display assembly, be sure the washers are closest to the screw head (as seen in the second picture).
Stap 10  ¶
Loosen the three large-headed Phillips screws along the other side of the iPhone about one half turn.
Stap 10  ¶
  • Loosen the three large-headed Phillips screws along the other side of the iPhone about one half turn.
Stap 11  ¶
Use the edge of a plastic opening tool to gently pry up the display assembly around its perimeter. Press gently on the home button to push it through the display and make sure it stays behind as the display separates from the iPhone. Otherwise, the home button cable may tear. De-route the digitizer and LCD cables through the steel inner frame.
Stap 11  ¶
  • Use the edge of a plastic opening tool to gently pry up the display assembly around its perimeter.
  • Press gently on the home button to push it through the display and make sure it stays behind as the display separates from the iPhone. Otherwise, the home button cable may tear.
  • De-route the digitizer and LCD cables through the steel inner frame.
  • When reinstalling the display, carefully straighten the digitizer and LCD data cables, and feed them through the slot cut in the steel frame. This photo shows the display assembly being installed incorrectly, with a fold in the digitizer cable.
  • When the front panel has been correctly installed, both the LCD and digitizer cables should be immediately next to one another and should be the same length, as shown in the second photo.
  • If the digitizer cable has been installed incorrectly, it will not reach its socket on the logic board. Do not attempt to pull it through by force, or it will tear. Remove the display assembly, straighten the cable, and feed it through to its full length, as shown.
  • During reassembly, do not touch the metallic area at the base of the LCD data cable, as this can cause problems with the LCD. If you do touch it accidentally, clean it gently with an alcohol wipe before continuing.
Stap 12  ¶
Remove the display assembly from the iPhone. Be sure to separate the home button from the front panel. If the home button sticks to the front panel you may tear the home button cable.
Stap 12  ¶
  • Remove the display assembly from the iPhone.
  • Be sure to separate the home button from the front panel. If the home button sticks to the front panel you may tear the home button cable.
  • When replacing the display assembly, note the following:
  • You may have to reuse the earpiece grille and the clear plastic ring around the front facing camera from the old/damaged assembly. This will depend on where you buy the replacement part.
  • Your replacement display may come with colored plastic film on the back of the LCD. If so, use the pull tab near the home button to peel the plastic film from the LCD before installing the new display in your iPhone.
  • After reassembly, note the following:
  • Clean the touchscreen surface with an alcohol wipe prior to turning the iPhone back on. The alcohol helps dissipate any lingering static electricity, which can cause problems with the display.
  • After reassembly, connect the iPhone to an AC power source before turning it on for the first time. Once the iPhone has booted up successfully, you can disconnect the AC power.
