Help
Fujitsu LifeBook N3510 Display Replacement
Effectively replace the display on your Fujitsu LifeBook N3510 by following this guide.
  • Auteur: Neil Daniels
  • Geschatte tijd: 5 minuten
  • Moeilijkheid: Gemiddeld
Following these steps, you can effectively replace your display.
Secties
Stap 1 Display  ¶
Remove labeled screws.
Stap 1 Display  ¶
  • Remove labeled screws.
Stap 2  ¶
Remove the screws from the bottom of the hinge as shown in the image.
Stap 2  ¶
  • Remove the screws from the bottom of the hinge as shown in the image.
Stap 3  ¶
Use a spudger to detach and remove cables from the motherboard. Use a spudger to detach and remove cables from the motherboard. Use a spudger to detach and remove cables from the motherboard.
Stap 3  ¶
  • Use a spudger to detach and remove cables from the motherboard.
Stap 4  ¶
Unplug highlighted cables from the wireless module. Unplug highlighted cables from the wireless module. Unplug highlighted cables from the wireless module.
Stap 4  ¶
  • Unplug highlighted cables from the wireless module.
Stap 5  ¶
Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body. Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body. Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
Stap 5  ¶
  • Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
