Ga door naar hoofdinhoud
Help
Fujitsu LifeBook N3510 Hinge Cover Replacement
  • Auteur: Neil Daniels
  • Geschatte tijd: 5 minuten
  • Moeilijkheid: Gemiddeld
The hinge cover has the computer power button, wireless switch, and volume toggle.
Secties
Gereedschap
Stap 1 Hinge Cover  ¶
Use a spudger to lift the back of the hinge cover on the left and right sides of the computer. Use a spudger to lift the back of the hinge cover on the left and right sides of the computer. Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
Stap 2  ¶
Lay the computer flat on a stable surface with the monitor pointing away from you.
Stap 2  ¶
  • Lay the computer flat on a stable surface with the monitor pointing away from you.
Stap 3  ¶
Use a spudger to partially lift the hinge cover. Use a spudger to partially lift the hinge cover. Use a spudger to partially lift the hinge cover.
Stap 3  ¶
  • Use a spudger to partially lift the hinge cover.
Stap 4  ¶
The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly. Lift the hinge cover enough to expose the ribbon cable.
Stap 4  ¶
  • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
  • Lift the hinge cover enough to expose the ribbon cable.
Stap 5  ¶
Disconnect the ribbon cable from the  motherboard and remove the hinge cover from the computer. Disconnect the ribbon cable from the  motherboard and remove the hinge cover from the computer.
Stap 5  ¶
  • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
