Ga door naar hoofdinhoud
Help
PowerBook G3 Lombard Inverter Replacement
  • Auteur: iRobot
  • Moeilijkheid: Eenvoudig
The inverter powers the LCD backlight and is not a difficult part to replace.
Secties
Stap 1 Inverter  ¶
Grasp the orange display data cable and disconnect it from the logic board.
Stap 1 Inverter  ¶
  • Grasp the orange display data cable and disconnect it from the logic board.
  • Pull the display cable straight up so that it is vertical.
Stap 2  ¶
Grasp the thin display inverter board at its left end, push the left end forward to get the board beyond the tab, and then lift the entire board up.
Stap 2  ¶
  • Grasp the thin display inverter board at its left end, push the left end forward to get the board beyond the tab, and then lift the entire board up.
  • There are two tabs that hold the display inverter in place that you need to get past in order to pull the board free.
Stap 3  ¶
Disconnect the white inverter cable connector from the right end of the board.
Stap 3  ¶
  • Disconnect the white inverter cable connector from the right end of the board.
Stap 4  ¶
Disconnect the inverter plug, pulling directly up from the logic board.
Stap 4  ¶
  • Disconnect the inverter plug, pulling directly up from the logic board.
Stap 5  ¶
Your laptop should look approximately like this.
Stap 5  ¶
  • Your laptop should look approximately like this.
