Ga door naar hoofdinhoud
Help
iPhone 4 Verizon Dock Connector Cable Replacement
Alleen vereisten
Alleen vereisten
Houd er rekening mee dat dit slechts een vereiste handleiding is voor andere handleidingen.
Internal Prerequisite.
Internal prerequisite.
Stap 1 Dock Connector Cable  ¶
Remove the two 1.8 mm Phillips screws securing the dock connector cable to the logic board. Remove the thin metal dock connector cable cover.
  • Remove the two 1.8 mm Phillips screws securing the dock connector cable to the logic board.
  • Remove the thin metal dock connector cable cover.
Stap 2  ¶
Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
Stap 2  ¶
  • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
Stap 3  ¶
Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
Stap 3  ¶
  • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
Stap 4  ¶
Remove the 1.6 mm Phillips screw securing the pressure contact to the logic board near the vibrator. Remove the pressure contact.
Stap 4  ¶
  • Remove the 1.6 mm Phillips screw securing the pressure contact to the logic board near the vibrator.
  • Remove the pressure contact.
Stap 5  ¶
Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board. De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
Stap 5  ¶
  • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
  • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
  • When reconnecting the antenna wire be VERY certain that the round connector at the end of the wire is centered on its mating half on the motherboard before applying pressure. Failure to do so will likely destroy both halves of the connector.
