Help
iPhone 4 Verizon Cellular Antenna Replacement
Replace your iPhone 4 Verizon's cellular antenna.
Use this guide to replace the cellular antenna normally adhered to the speaker enclosure.
Stap 1 Cellular Antenna  ¶
Remove the two 1.6 mm Phillips screws securing the cellular antenna to the speaker enclosure.
  • Remove the two 1.6 mm Phillips screws securing the cellular antenna to the speaker enclosure.
Stap 2  ¶
Starting near the cellular antenna cable, use the edge of a plastic opening tool to peel the antenna off the speaker enclosure. Continue peeling the cellular antenna off the speaker enclosure, being careful not to rip the gold bracket attached to one of its edges. Remove the cellular antenna.
Stap 2  ¶
  • Starting near the cellular antenna cable, use the edge of a plastic opening tool to peel the antenna off the speaker enclosure.
  • Continue peeling the cellular antenna off the speaker enclosure, being careful not to rip the gold bracket attached to one of its edges.
  • Remove the cellular antenna.
Stap 3  ¶
When installing a new cellular antenna, be sure to slide the gold bracket over the ear molded into the speaker enclosure before sticking the antenna down.
Stap 3  ¶
  • When installing a new cellular antenna, be sure to slide the gold bracket over the ear molded into the speaker enclosure before sticking the antenna down.
