Ga door naar hoofdinhoud
Help
Motorola E815 Keypad Replacement
Actiemomenten
Actiemomenten
Wees een actieheld! Deze handleiding heeft plaatjes nodig die beter tonen hoe specifieke handelingen uitgevoerd moeten worden.
Step-by-step guide to dissemble the Motorola E815 to access the phone's keypad.
  • Auteur: Zoie E
  • Geschatte tijd: 10 minuten
  • Moeilijkheid: Gemiddeld
If the buttons on your Motorola E815 are unresponsive or do not seem as crisp as they used to be, you may need to replace your keypad. To accomplish this, you will
  • Dissemble the phone
  • Access the keypad for repair or replacement
Secties
Stap 1 Keypad  ¶
Locate the two screws on the backside of the phone.
Stap 1 Keypad  ¶
  • Locate the two screws on the backside of the phone.
  • Unscrew the two screws using a T6 Screwdriver.
Stap 2  ¶
Gently pull the top section of the phone upwards until you feel some resistance. Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad. Using tweezers, gently pry the connector from the circuit board.
Stap 2  ¶
  • Gently pull the top section of the phone upwards until you feel some resistance.
  • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
  • Using tweezers, gently pry the connector from the circuit board.
  • Carefully detach the two sections of the phone.
Stap 3  ¶
Using the blue pry tool, carefully pull the keypad frame away from the keypad. Gently remove the keypad frame from the keypad. Lift the silicone keypad cover off.
Stap 3  ¶
  • Using the blue pry tool, carefully pull the keypad frame away from the keypad.
  • Gently remove the keypad frame from the keypad.
  • Lift the silicone keypad cover off.
Stap 4  ¶
Rotate the phone around so that you are looking at the battery cavity. Locate the screws on the bottom base of the phone.
Stap 4  ¶
  • Rotate the phone around so that you are looking at the battery cavity.
  • Locate the screws on the bottom base of the phone.
Stap 5  ¶
Rotate the phone back to the front side. Slowly lift the bottom portion of the keypad off of the phone until you feel resistance.
Stap 5  ¶
  • Rotate the phone back to the front side.
  • Slowly lift the bottom portion of the keypad off of the phone until you feel resistance.
Stap 6  ¶
Using tweezers, carefully detach the yellow connector strip from the circuit board by lifting up. Separate the keypad from the circuit board. Separate the keypad from the circuit board.
Stap 6  ¶
  • Using tweezers, carefully detach the yellow connector strip from the circuit board by lifting up.
  • Separate the keypad from the circuit board.
