Help
Dell Inspiron 9100 Fan 2 Replacement
Stappen inkorten
Stappen inkorten
Deze handleiding heeft onnodige stappen. Kort ze in om beknopter te kunnen zijn!
Removal of fan #2.
This guide requires a Phillips #00 screwdriver
Secties
Gereedschap
Stap 1 Fan 2  ¶
Undo the two screws on the fan cover labeled "F2" These screws will remain in the panel
Stap 1 Fan 2  ¶
  • Undo the two screws on the fan cover labeled "F2"
  • These screws will remain in the panel
  • Remove cover plate.
Stap 2  ¶
Remove the single 6mm screw holding the fan in place.
Stap 2  ¶
  • Remove the single 6mm screw holding the fan in place.
Stap 3  ¶
Flip the handle up. Use the handle to pull the fan away directly up, away from case.
Stap 3  ¶
  • Flip the handle up.
  • Use the handle to pull the fan away directly up, away from case.
