Ga door naar hoofdinhoud
Help
Canon PowerShot SD750 LCD Screen Replacement
Actiemomenten
Actiemomenten
Wees een actieheld! Deze handleiding heeft plaatjes nodig die beter tonen hoe specifieke handelingen uitgevoerd moeten worden.
Er moeten meer foto's
Een paar extra plaatjes zouden de procedure in deze handleiding glashelder maken.
This repair guide will show you how to replace the LCD screen for the Canon PowerShot SD750
  • Auteur: Stephen Gyugyi
  • Geschatte tijd: 10 - 15 minuten
  • Moeilijkheid: Gemiddeld
This repair guide will teach you how to replace the LCD screen for the Canon PowerShot SD750. The prerequisite for this guide includes taking off the casing for the camera.
Stap 1 LCD Screen  ¶
Flip the camera right side up.
Stap 1 LCD Screen  ¶
  • Flip the camera right side up.
  • Remove the silver 3.5 mm screw (located on top of the camera) with a #00 Phillips screwdriver.
  • Grip the corner of the A/V digital port and pull up and outward.
  • Note: You may encounter some resistance when removing the A/V digital port. Apply enough pressure in order to remove this piece.
  • Note: When reassembling, snap the corner plate back into its position. (Push down and inward)
Stap 2  ¶
Turn the camera forward so that the LCD screen is facing you.
Stap 2  ¶
  • Turn the camera forward so that the LCD screen is facing you.
  • Remove the silver 3.4 mm screw at the top right hand corner of the LCD screen with a #00 Phillips screwdriver.
Stap 3  ¶
Slide the LCD screen to the left of the camera and then gently pull the LCD screen away from the camera.
Stap 3  ¶
  • Slide the LCD screen to the left of the camera and then gently pull the LCD screen away from the camera.
  • Note: Hold the screen and frame together.
  • Be sure to align the screen properly.
  • Be gentile and do not tear the ribbon connector for the LCD screen to camera.
Stap 4  ¶
Locate the two ribbons connected to the camera and the LCD screen. (One is red and small and the other is  wide and orange) Remove the top left red ribbon  by gripping the connector on the camera and sliding it straight out.
Stap 4  ¶
  • Locate the two ribbons connected to the camera and the LCD screen. (One is red and small and the other is wide and orange)
  • Remove the top left red ribbon by gripping the connector on the camera and sliding it straight out.
  • Remove the side orange ribbon by gripping the connector on the camera and sliding it straight out.
  • Note: It may be helpful to use tweezers when removing the connectors. (Pay close attention to how the ribbons are disconnected as this will help in replacing the screen later)
  • Note: When reassembling, use tweezers to reconnect the small red connector on the top left of the screen.
