Ga door naar hoofdinhoud
Help
Canon Powershot SD750 Camera Case Replacement
Uitgelichte studenten-handleiding
Deze handleiding is het resultaat van het harde werk van onze geweldige studenten, en de iFixit-werknemers vonden de gids uitzonderlijk cool.
This guide helps you replace the camera casing.
  • Auteur: Memphis Wong
  • Geschatte tijd: 15 - 30 minuten
  • Moeilijkheid: Gemiddeld
You will need a #00 Phillips screwdriver to replace the camera's casing.
Make sure to remove the batteries before beginning the guide.
Stap 1 Camera Case  ¶
Turn the camera to the side that has the attachment for the wrist strap.
  • Turn the camera to the side that has the attachment for the wrist strap.
  • Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
Stap 2  ¶
Remove the plastic subsection by prying it with your fingers.
Stap 2  ¶
  • Remove the plastic subsection by prying it with your fingers.
  • Note: It may be helpful to pry from the bottom of the camera with the battery door open.
  • The wrist strap attachment behind the subsection will come loose and may fall out.
Stap 3  ¶
Turn the camera over to the side opposite of the wrist strap.
Stap 3  ¶
  • Turn the camera over to the side opposite of the wrist strap.
  • Remove the two silver 3.4 mm screws with a #00 Phillips screwdriver.
Stap 4  ¶
Flip the camera upside down.
Stap 4  ¶
  • Flip the camera upside down.
  • Remove the following screws with a #00 Phillips screwdriver.
  • One black 3.4 mm Phillips screw.
  • One silver 3.4 mm Phillips screw.
  • NOTE: Using your fingernails may help in removal.
Stap 5  ¶
Place the camera on the side opposite of the wrist strap handle.
Stap 5  ¶
  • Place the camera on the side opposite of the wrist strap handle.
  • Then begin to pry the casing apart with both hands by applying pressure to the top and bottom of the camera.
  • Remove the small metal plate underneath the plastic covering and set aside. (It should be loosely attached)
  • Note: A rubber foam washer that separates the lens from the casing will fall off when the case is removed. Be sure to store it safely.
  • Note: When reassembling ensure the back plate screw tabs are over the wrist strap attachment and the front plate screw tabs go under orange casing.
