Ga door naar hoofdinhoud
Help
PowerBook G3 Pismo Optical Drive Replacement
  • Auteur: iRobot
  • Moeilijkheid: Eenvoudig
It's easy to change or upgrade the optical drive mechanism to a combo or SuperDrive.
Stap 1 Optical Drive  ¶
Use the lever at the front of your laptop to remove the optical drive bay from the computer.
  • Use the lever at the front of your laptop to remove the optical drive bay from the computer.
  • Remove the 2 Phillips #00 screws from the left side of the optical drive housing.
  • These screws are longer than those on the other side.
Stap 2  ¶
Remove the 2 Phillips #00 screws from the other side.
Stap 2  ¶
  • Remove the 2 Phillips #00 screws from the other side.
Stap 3  ¶
Grasp the black drive housing in one hand and the drive itself in the other, then slide the two apart.
Stap 3  ¶
  • Grasp the black drive housing in one hand and the drive itself in the other, then slide the two apart.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
