Ga door naar hoofdinhoud
Help
HP Pavilion dv5000 Wifi Card
A step-by-step guide to accessing and removing the Wifi card for an HP Pavilion dv5000 laptop.
  • Auteur: Sam Kaplan
  • Geschatte tijd: 15 minuten
  • Moeilijkheid: Gemiddeld
The HP Pavilion dv5000 Wifi Card allows for wireless network connectivity. It is located on the mother board, beneath the RAM memory/Wifi compartment cover.
Secties
Gereedschap
Stap 1 Wifi Card  ¶
The wifi card is connected to the computer with the two antenna lead wires.
Stap 1 Wifi Card  ¶
  • The wifi card is connected to the computer with the two antenna lead wires.
  • Note where the white AUX wire and the black MAIN wire connect to the wifi card before disconnecting.
Stap 2  ¶
Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card. The white wire connects to the AUX terminal.
Stap 2  ¶
  • Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
  • The white wire connects to the AUX terminal.
  • The black wire connects to the MAIN terminal.
Stap 3  ¶
Remove the two 6.0mm screws securing the wifi card to the computer.
Stap 3  ¶
  • Remove the two 6.0mm screws securing the wifi card to the computer.
Stap 4  ¶
Remove the wifi card.
Stap 4  ¶
  • Remove the wifi card.
