Ga door naar hoofdinhoud
Help
Acer Aspire One ZG5 Motherboard Replacement
This guide will show you how to install a new motherboard.
  • Auteur: Doug Gallatin
  • Geschatte tijd: 20 minuten
  • Moeilijkheid: Gemiddeld
You will remove several cables, screws, and finally the motherboard. This opens up the device in order to repair practically everything.
Secties
Stap 1 Motherboard  ¶
Disconnect the display cable from the top left of the motherboard.
  • Disconnect the display cable from the top left of the motherboard.
Stap 2  ¶
Disconnect the speaker cable from its socket on the motherboard. Disconnect the speaker cable from its socket on the motherboard.
Stap 2  ¶
  • Disconnect the speaker cable from its socket on the motherboard.
Stap 3  ¶
Remove three 3.9 mm Phillips #1  screws from the small  I/O board.
Stap 3  ¶
  • Remove three 3.9 mm Phillips #1 screws from the small I/O board.
  • Remove a single 3.9 mm Phillips #0 screw from the front of the motherboard.
  • Some laptops may instead have a single 4.7 mm Phillips #0 screw.
Stap 4  ¶
Remove the two 4.7 mm Phillips #1 screws that connect the display to the motherboard.
Stap 4  ¶
  • Remove the two 4.7 mm Phillips #1 screws that connect the display to the motherboard.
Stap 5  ¶
Gently lift the I/O board up from the right side of the case.
Stap 5  ¶
  • Gently lift the I/O board up from the right side of the case.
  • The I/O board is attached to the motherboard by a short cable.
Stap 6  ¶
Lift the entire motherboard assembly out the case.
Stap 6  ¶
  • Lift the entire motherboard assembly out the case.
