Ga door naar hoofdinhoud
Help
LG Thrill 4G SIM/Micro SD Card Replacement
Verwarrende Tekst
Verwarrende Tekst
Een deel van de tekst in deze handleiding is verwarrend, dubbelop of naast de kwestie. Bewerk de tekst en maak hem duidelijker!
This guide will show you how to disassemble and reassemble the micro sim card board for the LG thrill 4G.
  • Auteur: Khbero Baker
  • Geschatte tijd: 15 - 20 minuten
  • Moeilijkheid: Gemiddeld
Before we begin disassembling your LG device, make sure your phone is turned off, make sure you have .the back cover and the battery detached to properly access the sim card board.
Secties
Stap 1 Ribbon Cable Disconnection  ¶
Utilize a spudger or plastic opening tool, and very gently disconnect the ribbon cable in two different areas, attached to the black micro SIM card board. Utilize a spudger or plastic opening tool, and very gently disconnect the ribbon cable in two different areas, attached to the black micro SIM card board. Utilize a spudger or plastic opening tool, and very gently disconnect the ribbon cable in two different areas, attached to the black micro SIM card board.
  • Utilize a spudger or plastic opening tool, and very gently disconnect the ribbon cable in two different areas, attached to the black micro SIM card board.
Stap 2 SD/SIM Card Board Removal  ¶
Carefully pry the board up to detach it from its lock bezel socket. Make sure to pry the little tab connected to the camera unit as well. Make sure to pry the little tab connected to the camera unit as well.
  • Carefully pry the board up to detach it from its lock bezel socket.
  • Make sure to pry the little tab connected to the camera unit as well.
