Ga door naar hoofdinhoud
Help
Canon PowerShot A590 IS Back Cover Replacement
Uitgelichte handleiding
De iFixit-werknemers vonden deze handleiding uitzonderlijk cool.
This guide will instruct the user on how to remove the back cover of the Canon A590 IS.
  • Auteur: Zach
  • Geschatte tijd: 5 minuten
  • Moeilijkheid: Eenvoudig
You will remove screws from the bottom and sides of the camera in order to remove the cameras back cover.
Stap 1 Remove Screw Near AV Port  ¶
Remove the screw located under the rubber flap on the left side of the camera using a magnetic screwdriver.
  • Remove the screw located under the rubber flap on the left side of the camera using a magnetic screwdriver.
Stap 2 Remove Side Screws  ¶
Remove the two screws located on the other side of the camera using a magnetic screwdriver
  • Remove the two screws located on the other side of the camera using a magnetic screwdriver
Stap 3 Remove Bottom Screws  ¶
Remove the three screws located at the bottom of the camera using a magnetic screwdriver.
  • Remove the three screws located at the bottom of the camera using a magnetic screwdriver.
Stap 4 Remove Back Cover  ¶
Open the battery cover.
  • Open the battery cover.
  • Using the iPod tool, push up gently around all edges of the camera.
