Help
Dell Inspiron 15-7537 RAM Replacement
This guide shows you how to remove and replace the RAM.
  • Auteur: Jean Whitmore
  • Geschatte tijd: 10 - 15 minuten
  • Moeilijkheid: Gemiddeld
Use this guide to replace the RAM if you would like to upgrade the RAM, or replace it if there is damage.
Secties
Gereedschap
Stap 1 RAM  ¶
Gently pull apart clips on the ends of the memory module until the memory module pops up. Gently pull apart clips on the ends of the memory module until the memory module pops up.
Stap 1 RAM  ¶
  • Gently pull apart clips on the ends of the memory module until the memory module pops up.
Stap 2  ¶
Pull the RAM out at a 45 degree angle.
Stap 2  ¶
  • Pull the RAM out at a 45 degree angle.
